Activity › Forums › Adobe After Effects Expressions › Expression for color control
Jarek Borzecki
January 29, 2013 at 11:52 pmit’s working fine now! my fault, dont ask what happened please
thank you again for your help!
J -
Goran Milovanovic
March 13, 2013 at 12:07 pmThis is amazing script. Is it possible that instead of random color I use float values in range from example -25,453 to 25.453. -value is blue and +value would be red like gradient. I have around 700 float values that i want to change into colors per frame.
I am new to scripting so I would appreciate any help
Thanks in advance -
Rob Mcdougall
June 12, 2013 at 8:49 pmHello all,
I’m wanting to control a colour scheme using a slider.
So, if slider = 1
circle = red
square = green
triangle = blue
when the slider value increased to 2 each fill layer would move on to the next object…
circle = blue
square = red
triangle = green
So, I understand that I need to make a range of colour controls, then I want to store them in a list. What I don’t understand is how to chose a specific colour (or member of the index) based on the slider value. Any suggestions?
Dan Ebberts
June 12, 2013 at 9:02 pmAssuming your colors are stored in an array named “colors”, and your slider control value is ‘slider’, you could calculate an index for each layer like this:
idx = ((index-1) + Math.floor(slider))%colors.length;
colors[idx]You might have to modify the index-1 if your shape layers aren’t at the top of the layer stack.
Dan
Brandt Weisman
July 25, 2013 at 8:43 pmThis works great. Is there anyway to control the duration of the color cycle. Every frame is a bit fast for my needs. Thanks.
Matthew Newcomb
August 22, 2013 at 5:41 pmHi, Not sure if you ever got an answer to your question, but if you did would you mind sharing it with me? I’m not very good at expressions yet!
Will Mcmillian
September 6, 2016 at 12:32 amTo make this last longer than a single frame, this worked for me; pre-comp and enable time-remapping to your new layer. Then apply this expression to the time re-mapping:
framesToTime(Math.floor(timeToFrames()/4));
Greta Senne
April 7, 2017 at 10:06 amHey,
im using your code just added a little time-tweak. I have this Code on an Adjustment Layer because i have multiple layers that i want to change between the colors – but randomly in time. right know everything is changing together.. i hope you understand what i mean.i think it could work about the “index”?!
— thank you —
here the code again (just added this holdTime-lines)
l=thisComp.layer("Colors");// retrieve colors stored in the color controls
i=1;
colors=[];try {
while(l.effect(i)) {
// an effect exists, but is it a color control ?
// We'll check if it's first parameter is called "Farbe"
if (l.effect(i)(1).name=="Farbe") {
colors.push(l.effect(i)(1).value); // store the color in a list
i++;
} catch (e) {}// Now if the list of colors contains any elements
// we will get a random value from the list.if (colors.length) {
holdTime = .5;
seed = Math.floor(time/holdTime);
seedRandom(seed,true);r=Math.floor(random(colors.length)); // a random integer
colors[r]; // return the color} else {
// the list of colors is empty, so we use the existing color value.
value;
