Activity › Forums › Adobe After Effects › Expression for camera shake
Posted by Avrohom Kohn on July 27, 2005 at 1:40 amCan anyone give an expression for camera shake? I once saw and it’s pretty simple, I just can’t remember it.
Thanx,
-A.N.Michael Rothenberg replied 21 years, 1 month ago 7 Members · 8 Replies -
Andrew Kramer
July 27, 2005 at 3:06 amhttps://www.videocopilot.net/tutorials.html
There is a linear way to create camera shake using the wiggler at the bottom.
You can also use the wiggle expression and apply it to your target and your camera position.Good luck,
Andrew -
Mike Clasby
July 27, 2005 at 6:21 amQuaker, at the bottom of this page:
https://scottfrizzle.com/free.html
A least with this you won’t have to have a problem with losing resolution (size) as you shake the layer if done with a position expression. Quaker fills in the gaps it makes. This isn’t an expression, but a preset, it may or may not work for you, but it’s free and a fun/useful item.
Realethan
July 27, 2005 at 10:41 amApply this to your clips position proprty: wiggle(.5,20)
and this to its rotation property: wiggle(.5,2)
dork around with the numbers until you get something you like.
Michael Rothenberg
July 27, 2005 at 6:18 pmI’m trying to use a wiggle expression on the Position property but I only want to wiggle the horizontal. I can’t figure out how to limit it to the x axis. Is there any way to do this without the Wiggler? I’m on 5.5 w/o PBundle.
thanks – Mike
Michael Rothenberg
Peak Productions -
Filip Vandueren
July 28, 2005 at 12:46 amit’s been asked before, so do a search for “wiggle one axis” for some more explanations,
but here’s the jist:
p=position;
w=position.wiggle(.5,20);
[w[0],p[1]];
Michael Rothenberg
July 28, 2005 at 5:01 pmBeautiful. Thanks for the resources and the help.
Much appreciated.
– Mike
Michael Rothenberg
Peak Productions
