Activity Forums Adobe After Effects Expressions expression for a solid with a drop Shadow fx
  • expression for a solid with a drop Shadow fx
    Posted by Yael Tal on March 10, 2013 at 6:02 am
    Hi all,
    I am trying to write an expression for a solid with a drop Shadow fx: when the solid scale has no key frames, drop shadow distance is 0, when solid scale gets bigger, drop shadow distance gets bigger (up to 18 distance), I did succeed writing something that actually works (used the pick whip)
    transform.scale[0]+value-550
    I added the value -550 because the shadow distance was not correct… my layer’s scale amount is from 100%-to-575%
    , BUT….. the problem is that the shadow distance is “jumping” from 0 to 18 in 1 frame and not actually growing over the time i gave for the scale key frames…..Thanks in advanced!
    Yael Tal replied 13 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 10, 2013 at 6:25 am
    Does this do what you need?
    linear(transform.scale[0],100,575,0,18);
    Dan
  • Yael Tal
    March 10, 2013 at 7:36 pm
    This is exactly what i need!
