Activity Forums Adobe After Effects Expression error using Checkbox control
  • Expression error using Checkbox control
    Posted by Brock Jolet on March 24, 2010 at 8:48 pm
    I’m trying, for the first time, to create an expression that controls a value depending on whether or not a keyed checkbox is on. This is my code.
    x = comp(“overlay grain”).layer(“frame”).transform.position;
    If (effect(“Frame Stutter”)(“Checkbox”) == true)
    value = x + wiggle(25,5);
    Else
    value = value + wiggle(25,5);
    When I run this, I get the error:
    After Effects warning: Function If is undefined
    Expression disabled.
    Error occurred at line 3.
    Comp: ‘main’
    Layer: 1 (‘Date Stamp’)
    Property: ‘Position’
    I have been racking my brain over what the problem is. I have used If/Else statements in the past successfully and I know that there is just something very simple that I am missing. I have also tried using “== 1” instead of “== true”, but I got the same result.
    Help please.
    Brock Jolet replied 16 years, 6 months ago 32,976 Members · 1 Reply
  • Brock Jolet
    March 24, 2010 at 9:00 pm
    Just figured it out guys. “if” cannot be capitalized. Hope this helps someone else.
