Activity Forums Adobe After Effects Expressions Expression created with pickwhip not working?
  • Expression created with pickwhip not working?
    Posted by Grant Muir on May 4, 2020 at 6:04 am
    Not sure what I’m doing wrong here.
    So I have a text layer dynamically generating a 5min count down. I am then trying to use Hacker text (Red Giant Universe) with the Text Target CUSTOM pickwhipped from the Source Text of the text layer.
    I have tried inputting the expression to generate the 5min count down directly into the Text Target Custom and get this error.
    Can anyone help??
    Chris Scalzo replied 3 years ago 3 Members · 3 Replies
  • Dan Ebberts
    May 4, 2020 at 1:58 pm
    That property has a custom data type so I’m guessing you can’t link it anything except maybe the same parameter from another instance of that effect.
    Dan
  • Grant Muir
    May 4, 2020 at 11:36 pm
    OK thanks.
    Guess I’ll have to find another way to skin that cat 🙁
  • Chris Scalzo
    August 9, 2023 at 2:11 pm
    I know it is years later, but I am dealing with this same issue right now. No idea why they couldn’t just use text and change the data type afterwards. 😞
