Activity Forums Adobe After Effects Expressions Expression Count Up Percentage
  • Expression Count Up Percentage
    Posted by Lisa Ruiz on September 2, 2009 at 10:41 pm
    I would like to know if anyone knows of an expression that will let you count up a number with a percentage sign. For example I would like the initial number to read 0% and count up to 100%. I have tried to alter an expression I have that allows a dollar sign and I get an error. Any info would be appreciated.
    Christoph Heimer replied 9 years, 8 months ago 11 Members · 24 Replies
  • 24 Replies
  • Dan Ebberts
    September 3, 2009 at 12:09 am
    A text expression like this should work:
    beginCount = 0;
    stopCount = 100;
    beginTime = 0; // start counting at time = 0
    countDur = 4; // count for 4 seconds
    “” + Math.round(linear(time,beginTime,beginTime + countDur,beginCount,stopCount)) + “%”
    Dan
  • Lisa Ruiz
    April 27, 2010 at 10:55 pm
    Thank you. This expression worked perfectly.
  • Lisa Ruiz
    September 14, 2010 at 4:36 pm
    I’m going to use this expression again, but I need to add a decimal. Do you have an expression for that?
    I need to go from 12.3% to 10.1%
  • Dan Ebberts
    September 14, 2010 at 5:07 pm
    Try this:
    beginCount = 123;
    stopCount = 101;
    count = linear(time,beginTime,beginTime+countDur,beginCount,stopCount)/10;
    count.toFixed(1) + “%”
    Dan
  • Fasasi Olabanji
    October 8, 2012 at 2:34 pm
    i was have same problem here too but as i Google for solution i saw this post under the search result and it just answer my question thanks for this post.
    beginCount = 0;
    stopCount = 100;
    "" + Math.round(linear(time,beginTime,beginTime + countDur,beginCount,stopCount)) + "%"
  • Conrad Dsouza
    December 24, 2012 at 10:18 am
    useful expression .. but how can I ease-in or ease-out the %tage countdown/countup?
    beginCount = 0; stopCount = 100; beginTime = 0; // start counting at time = 0 countDur = 4; // count for 4 seconds "" + Math.round(linear(time,beginTime,beginTime + countDur,beginCount,stopCount)) + "%"
  • Dan Ebberts
    December 24, 2012 at 5:56 pm
    Try changing “linear” to “ease” or “easeIn” or “easeOut”.
    Dan
  • Iqbal Muhammad
    February 14, 2013 at 10:30 am
    thanks dan , and how if i want give symbol in front of number ?
  • Dan Ebberts
    February 14, 2013 at 6:35 pm
    Just add it in front like this:
    “$” + count
    Dan
  • Chandra Hope
    June 25, 2013 at 9:51 pm
    Hi there, how could I make this do the opposite and make it count backwards? I tried playing with some of the text but was way off 🙂
    (I already got it to work by just making it a pre-comp and then reversing the time for the purposes of getting what I need done fast, but I was just curious what the code would look like 🙂 )
Page 1 of 3
