Activity › Forums › Adobe After Effects Expressions › Expression Count Up Percentage
Christoph Heimer replied 9 years, 8 months ago 11 Members · 24 Replies
Joshua Bird
April 22, 2016 at 6:54 pmHi Dan,
Worked perfect. Thank you. So I can learn more about the coding structure for AE can you explain what each number in this string represents (v1, 87, 100, 0, 100)?
Does:
v1 rep the opacity of layer 1 at any given time
87 target start value of layer 2
100 end value of layer ?
0,100 change opacity of layer 2 from 0-100Thanks,
Josh
Dan Ebberts
April 22, 2016 at 7:08 pm>v1 rep the opacity of layer 1 at any given time
Yes.
The second line of the expression essentially says “as the opacity of layer 1 varies from 87 to 100, vary the opacity of this layer from 0 to 100”. It’s in the AE help manual under Interpolation methods.
Dan
Christoph Heimer
January 4, 2017 at 4:57 pmThanks for all the good advice so far. But how is it possible to make the percentage “slider controllable”?
Basically what I wanna do is take this: https://vimeo.com/108922785 and add a fourth number, that is being controlled be a sum of two of the other numbers. But I can’t figure it out how to add the two numbers on top of each other. So I either need to understand that, or come up with a way to have a slider on my text layer that simply controls the number.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
