Activity › Forums › Adobe After Effects › Expression and Masking
Posted by Brad Strickman on March 30, 2007 at 5:59 pmI am trying to make a curtain that subtly blows in the wind. Fractal noise on a solid is working great except for one issue. The bottom of the solid remains a hard edge. Is there a way to make it so the fractal noise expands beyond the edges of the solid? My other idea is to create a mask and then add a wiggle expression to its shape. Is that possible? Any suggestions? Thanks
Brad Strickman replied 19 years, 5 months ago 5 Members · 10 Replies -
Darby Edelen
March 30, 2007 at 6:58 pmIf you pre-compose the curtain and make sure that there is transparent space around the curtain layer (easiest way might be scale it down 5%) in the pre-comp the displacement map should displace the ‘edges’ of the curtain.
Adolfo Rozenfeld
March 30, 2007 at 7:10 pmYou can’t apply wiggle() to a mask path, because the nodes’ locations aren’t exposed to expressions.
In CS3 you’ll be able to apply the Wiggle Paths operator (sounds pretty good, doesn’t it?) to a bezier shape path, which is identical and compatible with mask paths.
Adolfo Rozenfeld
Buenos Aires – Argentina
https://www.adolforozenfeld.com
adolfo(AT)adolforozenfeld.com -
Brad Strickman
March 30, 2007 at 9:12 pmI attempted scaling and precomposing and the same problem exists. The bottom edge of the curtain remains static. Any other ideas?
Darby Edelen
March 30, 2007 at 9:27 pm[bdstric] “I attempted scaling and precomposing and the same problem exists. The bottom edge of the curtain remains static. Any other ideas?”
Nope, but I still have the same idea =)
You go the order wrong there, pre-comp and then scale inside that pre-comp… The goal is to make a layer (a pre-comp) that has your curtain solid in it but with a buffer of at least 20 pixels of transparency surrounding it. So if your curtain layer is 720×480 and your displacement is 720×480, pre-comp your curtain layer into a 720×480 composition then scale it down so that the curtain layer is about 700×460 inside a 720×480 comp. Then the displacement map will displace the entire 720×480 pre-comp. You’ll still have ‘hard edges’ but those ‘hard edges’ will be on the transparent pixels at the border of the 720×480 pre-comp (so you won’t see any hard edges).
Note that the 20 pixel buffer I mention here is pretty arbitrary, it really depends on your maximum displacement values in the displacement map effect. A 20 pixel buffer would work for a maximum displacement of up to 20.
Ronaldo
March 30, 2007 at 11:25 pmThis may not be very helpful to you but Cinema 4D has a great was to do this. If you have access to it, let me know and I’ll fill you in.
All the best.All the best
Mike Clasby
March 31, 2007 at 1:10 amYou can wiggle a mask’s verticies with expressions, it’s a little round about, see this:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=897730
Adolfo Rozenfeld
March 31, 2007 at 2:40 amExpressions can’t access mask nodes directly. Scripting can, as the link you mention shows.
Adolfo Rozenfeld
Adolfo Rozenfeld
March 31, 2007 at 6:59 amTrue 🙂
Adolfo Rozenfeld
