Activity › Forums › Adobe After Effects Expressions › expression advice
  • Posted by Mark Cookman on February 13, 2006 at 1:03 pm
    I have time remap on and have put some keyframes in there – i want to cycle the last few keyframes for ever, loop_out (“cycle”,3) – plays the first part of my keyframes and -3 does nothing, do you know how I should form the expression?
    Mark Cookman replied 20 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 13, 2006 at 2:22 pm
    Assuming that you turned on time remapping, dragged the layer duration gizmo to the right, and added at least three keyframes between the two that AE created when you turned on time remapping, then you should get looping at the end that doesn’t include the stuff before the first keyframe that you added.
    If you did something else then it’s hard to say.
    Dan
  • Mark Cookman
    February 13, 2006 at 5:56 pm
    Thanks for such a prompt reply Dan.
    I also got help from your looping tutorial, its beautiful work.
