Activity Forums Avid Media Composer Express Pro and DV50
  • Express Pro and DV50
    Posted by Eli Tishberg on June 27, 2007 at 2:23 am
    Hi there.
    I need to move a project that will be captured in DV50MXF on a symphony over to my laptop (with external Firewire 800 of course) and had a few questions. I will NOT be using a Mojo.
    1- Am I correct in that the AXP MUST have MXF media and will not work with OMF?
    2-Will DV50 play off of a single (obviously unstriped) firewire800 drive?
    3- Multicam on AXP – will it do 9 streams or only 4? AND will it play 4 streams (or 9) in DV50 or should I capture at DV25?
    I don’t really have any experience with AXP but have lots of experience on composer and symphony. I would use the standalone MC software but don’t want to spend 5k.
    Thanks…eli
    Eli Tishberg replied 19 years, 2 months ago 2 Members · 3 Replies
  • Michael Hancock
    June 27, 2007 at 2:48 am
    [etishberg] “Hi there.
    No. AXP handles OMF and MXF. You decide which you want in your project settings.
    I’d think so. I’ve played 2:1 off firewire so I imagine DV50 wouldn’t be a problem..
    3- Multicam on AXP – will it do 9 streams or only 4? AND will it play 4 streams (or 9) in DV50 or should I capture at DV25?”
    If it doesn’t play DV50 well, transcode to DV25, cut your multicam, delete the DV25 and relink to DV50.
    Michael.
  • Michael Hancock
    Accidentally deleted part of my post before I posted it! In answer to multicam–AXP does 4 streams, not 9.
    Michael.
  • Eli Tishberg
    June 27, 2007 at 4:02 pm
    michael,
    Thanks for your fast response. I figured that AXP only did 4 multicam streams , and everything else is also pretty much what I though.
    Thanks again…
    eli
