Activity Forums Panasonic Cameras Express 34 expansion
  • Express 34 expansion
    Posted by Matthew Romanis on December 19, 2007 at 9:39 pm
    Does any one know if it is possible to expand the express 34 port on MCB pro laptops to allow 2 simultaneous Express 34 options to work. What I am interested in doing is running the duel adapter for P2 and a sata drive at the same time. I’m looking for the fastest data rates between the P2 card and storage drive.
    Thanks.
    PS. Has been posted on Mac/ OSX forum too.
    Michael Sacci replied 18 years, 9 months ago 4 Members · 4 Replies
  • Noah Kadner
    December 19, 2007 at 10:04 pm
    Haven’t seen such a device- not sure if the bus permits that sorta thing.
    Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
  • Michael Sacci
    December 20, 2007 at 8:15 pm
    If you get a FW800 drive you get excellent transfer time with the duel adapter. I buy drives with eSata and FW800 connections so I can dump to the FW800 and then use the eSata to do to decks with the AJA Io.
  • Chris Baldwin
    December 27, 2007 at 8:41 pm
    “and then use the eSata to do to decks with the AJA Io.”
    Sorry I’m curious what you meant by the above part of your post?
  • Michael Sacci
    December 27, 2007 at 9:01 pm
    Sorry, sometimes my figures and mind don’t work together.
    I buy drives with FW800 and eSATA ports. I hook the drive up via FW800 when transferring P2 cards in the Duel Adapter, then if I have the AJA Io hooked up I use the eSATA port to a express 34 card.
