Activity › Forums › Apple Final Cut Pro Legacy › Exporting XML with Motion Parameters
  • Exporting XML with Motion Parameters
    Posted by Patrick Simpson on May 16, 2012 at 1:26 am
    I’m preparing to send a project to a colorist via EDL.
    The project includes a bunch of clips with Motion Tab paramater adjustments such as Scale and Center (which don’t transfer with the EDL). I’m trying to figure out a way to create a list of the clips with Motion Tab parameter adjustments. I’ve been searching around and I can’t believe there’s not a way to open an XML as a spreadsheet with fields something like this…
    Name—————Scale–Center
    MVI_0995.MOV—118—-0, -119
    MVI_0851.MOV—117—-0, -78
    …so that the colorist can easily make these adjustments manually on the clips. There are some utilities that will parse an XML into a spreadsheet format (FCP XML Analyzer, XML2Text, readXML) but they only seem to list the other attributes like, in/out points, duration and comments. Any ideas?
    Jeremy Garchow replied 14 years, 4 months ago 2 Members · 3 Replies
