Activity › Forums › Sony Cameras › Exporting XDCAM HD from FCP to PDW f70?
  • Exporting XDCAM HD from FCP to PDW f70?
    Posted by Ken Libby on October 26, 2006 at 11:14 pm
    Import works perfectly, edit works perfectly, export, with everything set as shown in the “white paper”, crashes FCP the moment I select “Export to Sony XDCAM HD. Disc is formatted correctly. Anyone done this before successfully?
    Steve replied 19 years, 11 months ago 2 Members · 1 Reply
  • Steve
    October 27, 2006 at 11:07 pm
    I was able to export out of FCP to PDW F70, But I did not format the disc. Try it without formatting.
    Note: I only had CBR output choices at 25Mbs, there were no settings for 35Mbs, The Sony folks said I should have HD output settings for 35Mbs. Can you check to see if you have these settings for HD 1080 24p
    @ 35Mbs VBR.
    I can import @ 35Mbs just fine no export to deck at this settings only @ 25Mbs CBR.
    Regards
    Steve
