Activity › Forums › Apple Final Cut Pro Legacy › Exporting with Chroma Key
  • Exporting with Chroma Key
    Posted by Andrew Benton on September 28, 2010 at 8:32 pm
    Hello,
    I am pretty new to editing and appreciate any help/suggestions you can offer. I am using FCE and have used the chroma key feature to add in an image behind my speaker in a video. I have made all of the adjustments to make the key look good in FCE, but when I export the video I am getting a small green hue behind the speaker. Why is this evident in my exported video and not in the FCE canvas. Is there anything I can do before I export to prevent this??? FYI I am exporting to M-Peg4 video.
    Thanks for the help!
    Andrew Benton replied 16 years ago 2 Members · 2 Replies
  • Rafael Amador
    September 29, 2010 at 2:08 am
    Hi Andrew,
    That probably shows that your Chroma-K is not perfect.
    To spot that in the Canvas, you need to set it at 100% or even zoom.
    Use a white for the background to see how its really works the chroma-k.
    Also try a black as background.
    rafael
    http://www.nagavideo.com
  • Andrew Benton
    September 29, 2010 at 6:19 am
    Hello Rafael,
    Thank you for you suggestion. I did try zooming into the canvas to get a sharper key. But, for whatever reason the exported video kept having some spillage. I finally added (or should say found) the green spill suppressor filter and that solved the problem.
    Thanks for you help, I appreciate it.
    -Andrew
