Activity › Forums › Boris FX Particle Illusion › Exporting with Alpha
  • Exporting with Alpha
    Posted by Steve Douglas on October 26, 2007 at 7:37 pm
    I’ve done it in the past but that was a very long time ago. I made a 600 frame clip that I exported as a QT movie to my desktop. Now I would like to export it again but with an alpha channel. The only problem is that when I go to the save output and reach the window that asks you to check the ‘alpha’ channel, it is grayed out. Not sure why or what I should do.
    Also, since I will be importing this into FCP for an HDV sequence, do you have recommendations for the best compression to pick. Its default is ‘video’
    Steve
    Elvis Deane replied 18 years, 11 months ago 2 Members · 1 Reply
