Activity Forums Adobe Premiere Pro Exporting Widescreen Footage? Blowing up in DVD output?
  • Exporting Widescreen Footage? Blowing up in DVD output?
    Posted by Devon Brown on December 21, 2008 at 10:15 pm
    Hello!
    I am behind (hopefully this will change soon) and am running Premiere 1.0, Encore 1.01 and AE 7.
    I never ran into this issue before (years ago when I started working with premiere and encore on a very amateur level), but when I export to burn to DVD, everything checks off as 16:9. My project is widescreen, when i export, i use the media encoder (mpeg 2 4 mb 2 pass) and i only change the aspect ratio to 16:9.
    No matter what I do, when I burn the DVDs it looks as if the whole screen has been expanded! lol
    Is this a premiere issue? I have transcoded from encore to specify 16:9 as well. what am i doing wrong? it must be me, right?
    Devon Brown replied 17 years, 4 months ago 3 Members · 11 Replies
  • 11 Replies
  • Eddie Lotter
    December 22, 2008 at 3:00 pm
    Please post a screen capture of the Adobe Media Encoder window showing the video settings.
    Cheers
    Eddie
  • Devon Brown
    December 22, 2008 at 3:14 pm
    I should have thought of that myself. Will do so when I get home today. Thank you Eddie!
    Devon
  • Devon Brown
    December 23, 2008 at 1:12 am
  • Eddie Lotter
    December 23, 2008 at 2:31 pm
    Hmm, the settings do indeed look correct. I forgot how little control one has in those old versions.
    I would recommend you export from PPro as DV AVI and do the MPEG transcode in Encore.
    Cheers
    Eddie
  • Devon Brown
    December 23, 2008 at 2:37 pm
    Hi Eddie!
    Yeah I tried that also to no avail! ack!
  • Eddie Lotter
    December 23, 2008 at 5:13 pm
    Please use a utility like GSpot to double-check that your clips are indeed anamorphic and not letterboxed.
    See these troubleshooting tips.
    Cheers
    Eddie
  • Vincent Rosati
    December 23, 2008 at 11:50 pm
    Hmmm. I agree with Eddie.
    Does the disc play incorrectly on just one player, or does it have the same issue on other players (standalone or computer)?
    Vince
  • Devon Brown
    December 24, 2008 at 8:34 pm
    I tested it on two different DVD players; mine and my neighbor’s.
  • Vincent Rosati
    December 24, 2008 at 10:36 pm
    Going back to your first post, is your source material 16:9 or are you exporting 4:3 as 16:9?
    I imagine that the video frame is stretched horizontally?
    Can you test the Adobe Media Encoder MPEG2 file on a desktop DVD player like power dvd?
    If it is stretched in power dvd, than it is likely to be stretched.
    Vince
  • Devon Brown
    December 25, 2008 at 2:19 am
    And this is where I get completely bewildered.
    My source is 16:9 from a Sony PD-150. My compositions (both in Premiere and anything in AE) are 16:9. I export and set the export ratio to 16:9. In Encore, the timeline indicates the footage is 16:9.
    When I watch the AVI export in Media player – it is 16:9.
    When I transcode the file to 16:9 4mb (or even 7mb) and burn it, it plays full screen. More like the 16:9 footage is proportionately expanded to get rid of the bars.
