Activity Forums Adobe After Effects Exporting w/ alpha channel in after effects
  • Exporting w/ alpha channel in after effects
    Posted by Londonalleyent on August 30, 2007 at 12:45 am
    Im trying to export a logo I made in after effects 7 while keeping the alpha channel.
    As far as I know the only way to do this is with the Animation codec…. but this codec behaves very wierd when watched on a tv or when inported into Final Cut Pro.
    Are there any other ways to do this???
    thanks
    Luga
    Brendan Coots replied 19 years ago 2 Members · 1 Reply
  • Brendan Coots
    August 30, 2007 at 1:30 am
    The problem you are experiencing has nothing to do with the codec, except that it is a very high datarate, uncompressed file type. If it is playing back oddly in FCP, try tweaking your RT settings (on the left side of the timeline). Usually setting RT options to Dynamic or Low will allow high datarate files like this to play back smoothly.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
