Activity › Forums › Adobe After Effects › Exporting w/ alpha channel in after effects
  • Exporting w/ alpha channel in after effects
    Posted by Londonalleyent on August 30, 2007 at 12:45 am
    Im trying to export a logo I made in after effects 7 while keeping the alpha channel.
    As far as I know the only way to do this is with the Animation codec…. but this codec behaves very wierd when watched on a tv or when inported into Final Cut Pro.
    Are there any other ways to do this???
    thanks
    Luga
    Richard Harrington replied 19 years, 1 month ago 3 Members · 2 Replies
  • Michael Duff
    August 30, 2007 at 1:26 am
    I always use Animation codec when rendering out with an alpha… and never have any problems with using it in FCP (or DVD authoring etc)… maybe because animation is still a very large file your hard drives can’t read it fast enough?
    or you could try rendering out uncompressed … i can’t think of other codecs that support alphas at the moment, but I’m sure if you google/wiki it you find a few
  • Richard Harrington
    August 30, 2007 at 11:11 am
    Add it to your FCP timeline and render… then it will play fine….
    Make sure your timeline settings match your intended output (DV, 8 bit etc)
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
