Activity Forums Media 100 Exporting VHS Footage
  • Exporting VHS Footage
    Posted by Kwesi Johnson on November 22, 2006 at 10:00 pm
    I imported some VHS footage to the Media 100, put some titles on it, then exported it as a Media 100 movie. the image looked fine. I sent it over the network to another computer and now the image has a weird, studdering problem, like it’s been shot at the wrong frame rate. What could be causing this?
    Kwesi Johnson replied 19 years, 10 months ago 2 Members · 2 Replies
  • Juanjo Mora
    November 23, 2006 at 8:43 pm
    probably the other computer doesn’t has enough throughput to play the video in real time, specially if you digitized/exported yout video at a very high data rate (300KB/frame or Lossless).
    Usually you’ll transcode and/or compress your vido so any other machine will be able to paly it without stuttering or stopping.
    Maybe you should export your video from Media100 using the DV/DVCPRO codec, or H.264; or transcode to MPEG-1, MPEG-4 using Compressor, FFMPEG, Cleaner, etc. And play around with your quality and frame size settings so you can obtain pleasant results with a quality that satisfies you and/or your clients.
    HTH,
    Regards,
    Juanjo
  • Kwesi Johnson
    November 24, 2006 at 7:27 pm
    Thanks, I’ll try that
