Activity › Forums › VEGAS Pro › Exporting Vegas Pro 10 to DVD Architect Pro 5.0?
  • Exporting Vegas Pro 10 to DVD Architect Pro 5.0?
    Posted by Hideaki Ogiwara on April 30, 2011 at 8:21 pm
    I am wondering how I can exporting all my vegas session to DVD Architect Pro 5.0. I’m using Vegas Pro 10, but I can’t find any bottoms or something for exporting into DVD Architect Pro 5.0…
    I just thought Vegas Movie Studio HD is much easier to make DVD than using Pro 10….
    Please tell me how to exporting into DVD Architect Pro 5.0 from Vegas Pro 10’s session.
    John Rofrano replied 14 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Daniel Hughes
    April 30, 2011 at 9:26 pm
    Render in MPEG-2, selecting the relevant DVD Architect setting?
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
  • John Rofrano
    April 30, 2011 at 11:50 pm
    [Hideaki Ogiwara] “I can’t find any bottoms or something for exporting into DVD Architect Pro 5.0…”
    There is no button in Vegas Pro like Movie Studio. You must go to File | Render As… and select the Main Concept MPEG-2 render type and use one of the “DVD Architect” templates. If your project is widescreen, the DVD Architect NTSC Widescreen video stream template is your best choice. Then you have to render the audio separately using Dolby Digital AC-3 Pro and the Stereo DVD template, unless your project is 5.1 Surround, the use that template.
    If you give the video file and audio file the same name (only with different .mpg/.ac3 extensions) and DVD Architect will know that they go together and treat them as one file. Just drop the video file onto the DVD Architect menu and it will load the audio along with it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Hideaki Ogiwara
    May 1, 2011 at 5:39 pm
    Thank you very much! Now, I can export into DVDA from Vegas with my Chapter Mark.
    But here is another problem to burn. My data is 1h 50m and with top menu page it’s about 5.3 G so I couldn’t burn to DVD….
    Is this easy way to compress and burn the DVD which is only 4.7 G….
    Thank you very much.
  • John Rofrano
    May 7, 2011 at 1:43 am
    [Hideaki Ogiwara] “Is this easy way to compress and burn the DVD which is only 4.7 G….”
    If you render to an AVI file, DVD Architect will calculate the bit-rate for you and fit it all onto one DVD.
    Alternately you could use a bitrate calculator to figure out the bitrate needed to fit 1h 50m onto a DVD. Just Google “bitrate calculator”. You’ll find that the average bitrate should be around 5,300,000bps.
    ~jr
  • Hideaki Ogiwara
    May 7, 2011 at 1:46 am
    Thank you very much! I will try it!!
  • Joey Condeelis
    April 29, 2012 at 10:21 pm
    John I have Vegas Pro 11 How do I burn my timeline right to DVD like I do with my Vegas Movie Studio HD Platinum 11 where you just click on “make movie” and then click burn dvd.
    THANKS John
    Thank you
  • John Rofrano
    April 30, 2012 at 6:33 pm
    [Joey Condeelis] ” How do I burn my timeline right to DVD like I do with my Vegas Movie Studio HD Platinum 11 where you just click on “make movie” and then click burn dvd.”
    There is no simple “make movie” button in the Pro version. You can use Tools | Burn Disc | DVD… to burn a DVD from the timeline without menus (like a big VHS tape on disc).
    If you need menus, then you have to use File | Render As… and select MainConcept MPEG2 for your video and after rendering that select Dolby Digital AC-3 for your audio. Then take those two files into DVD Architect to create your DVD.
    ~jr
