Activity › Forums › Adobe After Effects › Exporting Troubles
  • Exporting Troubles
    Posted by Than Baardson on February 12, 2009 at 10:56 pm
    This should be a simple fix, but I’m pretty stuck at this point.
    All I’m trying to do is export my AE project to Premiere. When I export as an AVI, the color balance goes goofy, and when I try to bring it up in Premiere, it only includes one jpg image. Any ideas?
    Than
    Than Baardson replied 17 years, 7 months ago 2 Members · 2 Replies
  • Joseph W. bourke
    February 13, 2009 at 2:21 pm
    Hi Than –
    I would suggest trying a Quicktime export. It sounds as if you’re not set up to automatically link your AE project to Premiere (as in the Creative Suite), so that’s why you’re exporting.
    I regularly get good results with a Quicktime Motion JPEG-A setting at Best quality. I use lower field first, but I’m working in NTSC on most projects, and it also depends on whether I’m using footage or doing all graphics. The QT codec should do the trick. Good luck!
    Joe Bourke
  • Than Baardson
    February 13, 2009 at 5:48 pm
    Hey thanks Joseph,
    I actually just tried importing from Premiere rather than export from AE. Not sure why that made such a difference, (or why I didn’t think of it til I read your post) but it seems to have done the trick. Have it good,
    Than
    Than
