Activity Forums Apple Final Cut Pro Legacy Exporting Trouble: 24pa looks fine in timeline but all crazy in exported quicktime
  • Exporting Trouble: 24pa looks fine in timeline but all crazy in exported quicktime
    Posted by Amy Carpenter on April 6, 2009 at 10:31 pm
    My problem is that my project seems to be behaving fine in the timeline and then when I export it using Quicktime conversion, all hell breaks loose.
    Here are the stats:
    Camera: Panasonic HVX200a
    Shot at: 720×480 DV/DVCPRO NTSC 23.98fps (24pa) 48khz 16 bit
    Captured using: DV NTSC 48Khz Advanced (2:3:3:2) Pulldown Removal
    Sequence Preset: ?? (I think that I had it on DV NTSC but not on 24fps – so I changed it after editing it with no result, so no I have created a new project and sequence with the DV NTSC 24p sequence preset and have cut/pasted the entire sequence in there…it seems to need countless hours of render…might work??)
    Any help would be GREATLY appreciated…
    Thanks so much,
    ~Amy
    Josh Olenslager replied 17 years, 5 months ago 2 Members · 1 Reply
  • Josh Olenslager
    April 7, 2009 at 12:50 am
    What are your settings on export–final desired codec/interlacing cadence/etc.? What exactly are you seeing in the “all hell breaks loose” final version after export? What are the exact settings for your edited timeline?
    Josh
    Digital Media, Thought Equity Motion
