Activity Forums Adobe Encore DVD Exporting to SWF file : how to change skin of Flash Player
  • Exporting to SWF file : how to change skin of Flash Player
    Posted by Roger Chauvin on March 4, 2010 at 11:39 am
    I have burn a DVD which run fine, except for the text looking blurred on screen.
    So I have exported the project into SWF file, with a stage screen 640×480 (predefined size).
    I have got a lot of output files :
    “MyDVD”.swf,
    AuthoredContent.xml,
    menus converted into JPEG and PNG (for buttons),
    all the pictures of slideshows (several hundreds) converted into FLV files (1 frame per file),
    and video clips into FLV.
    When I launch the SWF file, it is running under Flash Player 8, and the transparent video control bar overlaps on the lower part of the pictures.
    I have installed Flash Player 10, but Flash Player 8 is still running when I launch the SWF file.
    I suppose that this version is embedded into my ENCORE CS3 soft.
    Is-there a way to change the default skin of the video control bar of Flash Player, for example switching to “SkinunderAll.swf” in order to have the control bar underneath the picture on screen ?
    Since there no FLA file generated during the export process, I cannot make any change into Flash pro CS3.
    Hoping for a solution…
    Amit kumar Gupta replied 16 years, 5 months ago 2 Members · 1 Reply
  • Amit kumar Gupta
    April 13, 2010 at 7:40 am
    >> FP is not embedded with SWF. SWF should run on the FP version you have install. I guess you have installed FP in a web browser and running SWF in another browser. Please check. If this is the case reinstall FP using the browser in which you are playing the SWF
    You cannot change the skin of the SWF. The control bar hides after few seconds on inactivity while SWF content is playing. It won’t remain forever there.
