Exporting to quicktime
Hi long time leecher first time poster:
I have exported a FCP sequence to a self contained quicktime using current settings. I have then imported that file into AE on windows and done some magic bullet looks suite work to it.
The footage is PAL DVCAM, i would like to know what export settings i should use to get the footage back at the same quality into my FCP timeline. I have used the h.264 compression setting to export from AE and noticed the file with the effected footage was smaller in size than the original file which worried me.
The export i have done also seems to jump or miss frames occasionally. Im not sure if this is because im using the quicktime player and whether it will sort it self out when dropped into the FCP time line. I cant check in FCP until im at uni again tomorrow.
Also what is the prepare for internet streaming checkbox for? i am assuming my choice not to tick it was correct?
