Activity Forums Adobe After Effects exporting to Quicktime for widescreeen
  • exporting to Quicktime for widescreeen
    Posted by Alex Kogan on May 9, 2006 at 8:49 pm
    I’m trying to export a DV1/DV NTSC 16×9 to a full-res qt movie and the result is a squished 4×3. Is there some setting in AE that I have to click when doing this? Thank you!
    Alex
    Wes Plate replied 20 years, 4 months ago 2 Members · 6 Replies
  • Wes Plate
    May 9, 2006 at 9:06 pm
    A D1 widescreeen comp is 4×3, it is the non-square pixels that make it widescreen.
    Nest your final D1/DV comp into a Square Pixel 16×9 comp and render that.
    — Wes Plate
    Automatic Duck
  • Alex Kogan
    May 9, 2006 at 9:11 pm
    Actually, this is a NTSC DV Widescreen 720 x 480. When I create a new comp and make it square pix it won’t let me use the widescreen present. What should I make the height and width. Thanks!
  • Wes Plate
    May 9, 2006 at 9:16 pm
    Create a new comp that is 853×480 SQUARE PIXELS, then drop your 720×480 DV Widescreen comp into it.
    — Wes Plate
    Automatic Duck
  • Alex Kogan
    May 9, 2006 at 9:41 pm
    When I do this, everything is off center to the left. Will this correct itself in the quicktime file or do i need to move everything?
  • Alex Kogan
    May 9, 2006 at 9:53 pm
    Nevermind. I cut and pasted. Not nested. I did that and it’s right. Thanks.
  • Wes Plate
    May 9, 2006 at 9:54 pm
    You should center your DV comp in the Square Pixel comp.
    The square pixel comp should actually be 864×480, sorry.
    Check it out:
    https://www.automaticduck.com/screenshots/dvwideintosquare.mov
    — Wes Plate
    Automatic Duck
