Activity Forums Adobe Premiere Pro Exporting to QuickTime
  • Exporting to QuickTime
    Posted by Brittany Dixon on August 12, 2009 at 8:20 pm
    Hello,
    I created multiple small videos (a minute to two and a half minutes) using Adobe Premiere Pro CS4.
    My sequence settings are as follows:
    General
    Editing Mode: DV NTSC
    Timebase: 29.97 fps
    Video
    Frame Size: 720 x 480 4:3
    Pixel Aspect Ratio: D1/DV NTSC (0.9091)
    Fields: Lower Field First
    Display Format: 30fps Drop-Frame Timecode
    Audio
    Sample Rate: 48000 Hz
    Display Format: Audio Samples
    Video Previews
    Preview File Format: NTSC DV
    Codec: DV NTSC
    I used these settings because I created the videos for television, but I now need to take those same videos and put them on a website for others to view using QuickTime. I need them to be 320 x 240 but can’t figure out how to do that using the Adobe Media Encoder. They just seem to stay at 720 x 480. Any help would be greatly appreciated as I’m not very understanding of the Media Encoder.
    Thank you.
    Shane Newville replied 17 years ago 2 Members · 2 Replies
