Activity › Forums › Adobe Premiere Pro › Exporting to DVd
  • Exporting to DVd
    Posted by Sandra Miller on July 18, 2006 at 2:23 pm
    I am having difficulties creating a dvd. I burned a copy that works on my computer and a television, however, it is jerky and skips on a compact dvd player and is not recognizable on other computers. When it goes into the duplicator machine, the discs are not copying any footage on the disc. Any suggestions?
    Bugeyed replied 20 years, 2 months ago 3 Members · 3 Replies
  • Alex Jusay
    July 19, 2006 at 2:33 am
    If your burned DVD (DVD video, not video in DVD) plays fine on your DVD ROM (PC or MAC, not DVD player), then the problem is in the disc. Change your disc brand and make sure to close or finalize your DVD.
    I hope that helps.
    Alex Jusay
    https://jhalex.sitesled.com
  • Sandra Miller
    July 19, 2006 at 11:47 am
    Thanks! I appreciate it. I ended up using the Media Encoder and creating the timeline from Encore DVD. The disc didn’t make copies, because I had it “copy” protect. Thanks again!
    Sandra
  • Bugeyed
    July 31, 2006 at 7:58 pm
    I’m using DVD+R and when I export to DVD from Adobe Premiere Pro 1.5, I can play the DVD on my computer workstation but I get an incorrect disc error when I try to play it on my DVD player. Should I switch to DVD-R? I’d like to be able to play the DVD on both the computer (PC) and DVD player. What settings should I use? I used NTSC 7mb 4:3 constant rate, 1 pass.
