Activity Forums Adobe Premiere Pro Exporting to DVCPro AJ-SD93 tape deck: no audio, video ok
  • Exporting to DVCPro AJ-SD93 tape deck: no audio, video ok
    Posted by Don Fito on July 21, 2011 at 9:12 pm
    Posting here in hopes of getting more insights, have also posted in the Adobe forum a few days ago:
    When exporting a sequence to a Panasonic AJ-SD93 deck over firewire there’s no audio on the tape after the export, video is there though.
    Sequence settings:
    editing mode: QT DV NTSC
    timebase: 29.97
    audio: 48k
    1 video track
    1 stereo audio track
    Sequence -> Sequence Settings -> Playback Settings… -> Export -> External Device: DV 29.97 720x480i
    Deck is set to record DVCPro.
    I’ve tried with and without device control, same result, video but no audio on the recorded DVCPro tape.
    On a side note, was surprised by the behavior of the Export to Tape dialog. Typing directly into the “Assemble at timecode” field a value such as “23:58:15;00” results in the field showing “23:58:14;29”
    And the preroll field setting, if I type a value in, actually overrides my “Assemble at timecode” value. So if a 5 second value is entered into the preroll field, recording on the tape actually starts 5 seconds before the value in the “Assemble” filed.
    System:
    CS5.5 trial
    Mac Pro 2,1 – x8 cores
    OS 10.6.6
    8 GB RAM
    ATI X1900 512MB video card
    Any tips appreciated
    Don Fito replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
