Activity Forums Avid Media Composer Exporting to a monitor with 24p.
  • Exporting to a monitor with 24p.
    Posted by Doug Bay on June 10, 2006 at 11:03 pm
    I have a 23.97 project. (I shot with the XL2 in 24p advance)
    I have a DAC-100 dv deck (Its a analog to DV converter). In Avid when I am in a 30i project I can export it to the DV device just fine. But when Im in 24p the option “Output to DV device” is not even available.
    How can I preview my 23.97 project via firewire to my dv device? Do I need to tell avid to do pull down first?
    Avid Xpress HD 5
    Doug
    Michael Phillips replied 20 years, 2 months ago 2 Members · 3 Replies
  • Michael Phillips
    June 11, 2006 at 1:06 am
    Output back out over FireWire without an Avid Mojo was part of the 5.0 release. Previous versions of Xpress Pro need Mojo regardless of Mac or PC. Mac gets this feature with the release in a few weeks.
    Michael
    anything 24fps
  • Doug Bay
    June 11, 2006 at 1:48 am
    So becuase I have Avid Xpress 5.2 HD without Mojo, I can not export my 23.97 project through a fire wire to a DV deck?
    Is that correct?
    Doug
    I have the academic version. it did not come with the Mojo.
  • Michael Phillips
    June 11, 2006 at 11:47 am
    As I said in my mail, that feature came in 5.0 which means you have that feature if you are using 5.2. Make sure you are in green/green mode first.
    Michael
    anything 24fps
