Activity Forums Adobe Photoshop Exporting titles from Photoshop to Final Cut Pro
  • Exporting titles from Photoshop to Final Cut Pro
    Posted by Miriam Millan on February 1, 2006 at 2:05 pm
    I need to find out how to create great tiles in Photoshop, with effects, layer styles, to later import into Final Cut Pro. The steps to achieve both, without loosing any work done in PS. Or is it just better to create all titles in Live Type???
    Thanks in advanced,
    Miriam
    Del Holford replied 20 years, 7 months ago 2 Members · 1 Reply
  • Del Holford
    February 2, 2006 at 1:21 pm
    [Miriam Millan] “I need to find out how to create great tiles in Photoshop, with effects, layer styles, to later import into Final Cut Pro. The steps to achieve both, without loosing any work done in PS.”
    Hi Miriam
    All you need to do is create your wonderfully creative photoshop files, then create alpha channels for the entire composition. Or you might want to create an alpha for each individual layer and save them individually like “Great art” for the entire comp., then “Great art 1” for the top layer, “Great art 2” for the 2nd layer and so on. Richard Harrington’s book Photoshop for Nonlinear Editors would help, as would the software from Tools for Television Pro from Glen Stephens, which I use every day to make alpha channels. These files can be psd or tif (or pict or tga if you like) and the alphas will cut the hole for the photoshop fill. If you size your composition to be twice the size of your project’s resolution then zooming or moving the layers doesn’t lose sharpness (After Effects has done this for years but I do in on my NLE).
    This may be an oversimplified explanation but I HTH.
    Del
    fire*, smoke*, photoshopCS
    Charlotte Public Television
