Activity Forums Adobe Premiere Pro exporting timeline without compression
  • exporting timeline without compression
    Posted by Ruby Gold on April 14, 2005 at 10:07 pm
    I’m using PPro 1.5 and want to export a portion of a captured clip (captured with PPro) to work on in After Effects 5.5, render there and then import the resulting avi back into my project in PPro to work with.
    Despite the fact that I’m exporting the portion of the captured clip with no compression, after exporting, it looks stepped on slightly (as compared with a clip that’s just been captured, but has not been exported from PPro). Is there something else I need to do/select/set when exporting from PPro’s timeline to have it look as “un-stepped on” as captured clips do?
    thanks-
    John Hand replied 21 years, 4 months ago 7 Members · 10 Replies
  • 10 Replies
  • Mike Velte
    April 15, 2005 at 11:51 am
    Is your source DV? What export settings did you choose?
  • Ruby Gold
    April 15, 2005 at 4:58 pm
    Yes, DV is my source, and my export settings were for DV AVI>DV (NTSC), recompress checked. It doesn’t seem to be doing it as bad now–so maybe it was a processor thing with my computer?
  • Mike Velte
    April 15, 2005 at 9:01 pm
    Your video is stepped on…several times.
    Microsoft DV degrades badly after 2 generations, especially the graphics. I use the Main Concept DV codec, about $50 for this type of work.
  • Ruby Gold
    April 15, 2005 at 10:33 pm
    Thanks for the response. So, how does the Main Concept DV codec work? Do you install it somehow within PPro 1.5? thanks-
  • Steven L. gotz
    April 15, 2005 at 11:08 pm
    I do not recommend checking “Recompress”.
  • Ruby Gold
    April 15, 2005 at 11:28 pm
    Okay, thanks. Why is it checked as the default?
  • Shaun999
    April 16, 2005 at 5:08 am
    Everytime you export the content of the timeline work area, are you making it into a new greneration ? i thought this was just rehandling digital information and wouldn’t count as a new generation copy ?
    Shaun
  • Gabriel
    April 16, 2005 at 10:14 pm
    The Recompress option is a big part of your problem. It’s adding a second generation of compression. This is that stepped on look you are seeing. It’s exagerated because the Microsoft DV codec is so unforgiving.
    Uncheck that option and see if it still works.
  • Mike Cook
    April 17, 2005 at 12:44 pm
    Ya know what else you can do? Get AE 6.5 and import your PPro project.
    No need to render and avi, just open the PPro porject in AE. Works great and saves time.
    ‘Course it’s gonna cost you…
    Mike
  • John Hand
    April 17, 2005 at 8:35 pm
    Here is what you do:
    Export timeline,
    export to movie,
    under General, Select Microsoft AVI
    under video compressor, choose NONE,
    make sure recompress is unchecked…
    That’s it.
    Your saved AVI timeline footage is pristine …..
    However, file size really goes UP UP UP (80mb original DV becomes 725mb uncompressed).
    Is it worth it. You bet it is.
    Jon R Hand
