Activity Forums Apple Final Cut Pro Legacy exporting tiff sequence without background
  • exporting tiff sequence without background
    Posted by Dan Rosenfeld on May 27, 2009 at 4:45 pm
    I am just finishing up titles for a short feature. the first three shots of the film have been scanned to have titles added to them. I made the titles in Live type and want to export them as tiff sequence. I have done this before without trouble.
    This time however i want the tiffs to be without black background, so it will be easier for the animation people to put them onto the scanned images.
    How do i get the image sequence to export without black background????
    Malte Rosenfeld
    d.o.p
    s i n g l e s h o t f i l m s
    Rafael Amador replied 17 years, 3 months ago 3 Members · 2 Replies
  • Chris Poisson
    May 27, 2009 at 6:16 pm
    You have to export using QuickTime Conversion, unless you set you sequence to Animation+. Either way will give you a transparent background.
    Have a wonderful day.
  • Rafael Amador
    June 1, 2009 at 11:49 am
    Hi Maite,
    As long as I know LiveType do not directly export Still sequences. You need to export a QT movie (Animation), then convert it to TIFF or any other format.
    You will get an Animation with Alpha channel when on exporting you uncheck “Render Background”.
    To keep the transparency in the still sequence, you need to export setting in your TIFF options “Millions of Colors+”
    rafael
    http://www.nagavideo.com
