Activity Forums Adobe After Effects Exporting the best way from after effects
  • Exporting the best way from after effects
    Posted by Max Marklund on January 11, 2007 at 3:09 pm
    Hi, I am wondering how the compression setting should be set to get the best quality? Cause I’m going to edit the things I’ve done in after effects with Final Cut, and after the edit then Im going to export it out to a final product.
    The things I want to export from after effects is a square pixel comp, with animations.
    Max Marklund replied 19 years, 8 months ago 56,973 Members · 1 Reply
  • Max Marklund
    January 11, 2007 at 9:56 pm
    Thank you very much for the answer and I’ve learned something new!!
    Best regards Max!
