Activity › Forums › Avid Media Composer › exporting subtitles from Avid
Strat Theo
May 26, 2017 at 9:38 amI got this from your e mail
MAILER-DAEMON@yahoo.com
To:rezenta@yahoo.com
May 26 at 10:43 AM
Sorry, we were unable to deliver your message to the following address.:
550: High probability of spam— Below this line is a copy of the message…..
do you have another e mail? or is there any other way to send it to you?
Bouke Vahl
May 26, 2017 at 10:39 am -
Bouke Vahl
May 26, 2017 at 12:49 pmOk, got your files, and it works fine on my system. (You should have a .txt file by now.)
So, ‘something’ is fishy with your Avid… (I have no clue what it is, either your version, or you need a clean install)
From the images I cannot tell you doing anything wrong, it just does not work on your system.Few other points, your work is a bit messy, contains double spaces, extra empty lines, spelling mistakes.
You should consider cleaning it before sending it out.Last but not least, for a feature with 900+ titles, you really should look at a dedicated subtitle app.
This is (after you’ve mastered it) way faster.
(My Subbits being one of them.) Shameless self promotion:
https://www.videotoolshed.com/product/subbits-subtitler/Bouke
http://www.videotoolshed.com -
Bouke Vahl
May 26, 2017 at 12:51 pmOh, in ‘Box appearance’, set it to ‘as many rows as needed’.
Then you will get bottom aligned text. (So a single line appears at the bottom, looks better.)hth,
Bouke
Strat Theo
May 26, 2017 at 2:48 pmThank you for your interest Bouke, I ‘ll keep in mind your notifications, (that was my first editing -I’m a director, usually I just give orders to somebody).
Any way, the good news is that the problem is SOLVED. I am not sure how, but I will put here my guess for the next despaired director. Maybe, the fact that I opened (for the 10th time) the edit caption, and without changing a thing –Noting at all- I closed it again, using the ok command instead of cancel made it work.
As magic it’s not my style, is the only explanation I can think.
Now , I’ll have a look on your subtitling app!
Thanks a lot!
