Activity › Forums › Adobe After Effects › exporting stills
exporting stills
Posted by Thomas c. Gass on February 25, 2010 at 8:22 amHi,
Is there a way to export still frames, let’s say 1 still every second? I’ve tried various things, but couldn’t find a way to achiebe this. Thanks for all hints,
ThomasThomas c. Gass replied 16 years, 7 months ago 3 Members · 5 Replies -
Todd Kopriva
February 25, 2010 at 1:44 pmSee “Rendering and exporting still images and still-image sequences”.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Thomas c. Gass
February 25, 2010 at 6:00 pmTodd,
thank you for your reply! I’ve had a look at this link, but it only describes exporting a sequence as stills, which is not my particular problem. I have a 3 hour recording from a survey camera and would like to render out just one frame every 30 seconds – can that be achieved with AE as well?
Thomas
Walter Soyka
February 25, 2010 at 6:52 pmSure; you’ll want to use time re-mapping to speed up your footage.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Thomas c. Gass
February 26, 2010 at 8:42 am🙂 Ok, here are more details about what I want to do:
I got a HD-Stream on harddisk, that was shot continuosly with a fixed camera angle showing the process of building up a large circus tent. The stream was already downsized to SD and upspeeded to make a time-lapse shot. In addition my client wants HD stills of every 10th second of the process for print. That’s 900 stills – far too much to export one by one out of FCP, AE or Quicktime. So I thought it might be possible to render out a still sequence via AE – but as I said: only every 10 seconds one frame. Of course I could render out ALL frames and delete the unwanted frames, but that’s 270.000 frames to render… :-/Thomas
Thomas c. Gass
March 1, 2010 at 1:11 pmHello Dave
thank you very much for your reply and your solution! Nevertheless, this procedure requires a lot of time… but it definitely is a way to accomplish the job. In the meantime I’ve found another workaround – I post it in case anybody else needs a similar solution:
– add the source file to a composition
– change the composition’s framerate to 1 frame / second
– add the composition to the render cue
– in the render dialogue set the frame rate option to: Use this frame rate: 0.1All the best
Thomas
