Activity › Forums › Apple Final Cut Pro Legacy › exporting Stills from HDV sequence? FCP 6.0.4
  • exporting Stills from HDV sequence? FCP 6.0.4
    Posted by Debbi Lucyk on July 25, 2008 at 10:48 pm
    Am using FCP version 6.0.4 with Quicktime 7.5 on Mac..
    The problem is that when exporting a still image from an HDV sequence it is squished – making the image taller and skinnier.
    I have tried converting the HDV sequence freeze frame into an SD sequence and exporting a still image from that SD sequence but then am getting an image that is again squished – making it shorter and fatter than the original.
    In the past, using SD source it was a no-brainer and a simple export as still image.
    Does HD Final Cut Pro need a bug fix to export stills and get an end result that is the same dimentions and look of the original? or is there a way around it?
    Please advise on how to pull a still from my HDV source footage..
    something so simple – embarrassing – what am I not doing? Tried jpeg then tiff – uncompressed setting – all the same result-stretched.
    thanks,
    digitaldebbi
    Carlo Mirabella-davis replied 17 years, 10 months ago 3 Members · 4 Replies
  • David Roth weiss
    July 26, 2008 at 12:04 am
    Debbi,
    Unfortunately, FCP exports anamorphic stills from anamorphic video, requiring a two step process that entails resizing in Photoshop.
    So, bring the stills you export from FCP into Photoshop, turn off the maintain ratio constraint, and resize as 1920×1080.
    Hope this helps…
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Debbi Lucyk
    July 29, 2008 at 1:10 am
    Thanks David,
    As I did not have photoshop on my laptop – out of desperation I found a way – and want to share…
    1. Stay out of final cut..
    2. Open the HD source file straight from the drive in Quicktime.
    3. find your frame and save as a still from there.
    Quicktime does not stretch the image.
    giving back,
    digitaldebbi
  • David Roth weiss
    July 29, 2008 at 1:42 am
    Good one Debbi.
    I often forget that while QT Conversion inside FCP seems at times to work excatly like QT Pro, it’s really a different beast altogether and has different rules and conventions.
    That’s a good find…
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Carlo Mirabella-davis
    December 1, 2008 at 7:30 pm
    I would strongly suggest that for those of you doing this kind of still exporting you do NOT go the Quicktime route. I just did a test, and the FCP still output, resized in Photoshop is much higher quality.
