Activity › Forums › Apple Final Cut Pro Legacy › exporting still to use to make mask in photoshop
  • exporting still to use to make mask in photoshop
    Posted by Victoria Murphy on August 21, 2008 at 1:20 am
    I need to export a still, open it in photoshop, make a mask from it, then import the mask into FC and use it for color correction purposes. I am exporting the still through the Export/Using Quicktime Conversion method. What format should I select in the Export Image Sequence Settings dialogue box?
    Thanks.
    Victoria
    Victoria Murphy replied 18 years, 1 month ago 2 Members · 4 Replies
  • Rafael Amador
    August 21, 2008 at 2:00 am
    Use PNG all the way.
    Rafael
    http://www.nagavideo.com
  • Victoria Murphy
    August 21, 2008 at 2:01 am
    How do PNG and TIFFs differ?
    Victoria
  • Rafael Amador
    August 21, 2008 at 2:30 am
    Hi Victoria,
    The two formats are call bit-map. Basically is the RGB information of each individual pixel and the position of the pixel.
    I really don’t know the difference between the two formats, but are two different ways to pack the same thing. PNG is one of the first graphic formats to be developed, so probably TIFF have some advantages (metadatas, profiles, color managing?), but as I tell you no difference in the picture quality. You can convert PNG to TIFF back and forward without any loose. To do your job you can use TGA too.
    Rafael
  • Victoria Murphy
    August 21, 2008 at 2:40 am
    Thanks, Rafael.
    Victoria
