Exporting still frame from HD footage.
Hey what is the best way to go about exporting the highest quality still frame from HD source? I need to export a frame so that I can open it up in photoshop paint it and then put it back in to cover a corner.
Also can anyone tell me the exact settings you need to set final cut 5 to in order to playback
APPLE FCP UNCOMPRESSED 10-bit 4:2:2. 1920 x 1080, Millions
16-Bit Integer (Big Endian), Stereo
48,999 kHz
FPS 23.98Data Rate 1063.67 mbit/sec
Everytime I drop these files into my sequence I need to render them. Is this normal? I am on a Dual 2 Ghz G5 with 3 gigs of memory. OS X ver 10.4.7
Any help would be much appreciated!
Mattt
