Activity Forums Adobe Premiere Pro Exporting stems to 8 xdcam audio tracks
  • Exporting stems to 8 xdcam audio tracks
    Posted by Eman Kayker on October 31, 2019 at 4:25 pm
    Hi all
    I need to export international versions of tv programmes in xdcam 8 tracks with separate audio stems:
    1-2 mixed programme
    3 direct voice
    4 voice over
    5-6 music
    7-8 sfx
    How do we route signal in adobe elsewhere than L R? couldn’t get submixes to do that
    thanks
    cheers from Geneva
    Shane Ross replied 6 years, 10 months ago 2 Members · 4 Replies
  • Shane Ross
    October 31, 2019 at 5:08 pm
    SO you aren’t having the audio mixed by a separate audio professional? Doing this yourself? I typically have the audio professional do the mix and provide the stems that I then put on the timeline in the proper order. If you don’t have a mixer, then you’ll need to make them yourself. This is one reason that I keep specific track assignments, so only INTV is on certain tracks, SOT on others, SFX on others, MUS on others, and then VO. This way, I can simply turn off tracks and export stems that are only MUS, or only VO, or MUS and SFX. Then reimport the separate stems
    Shane
    Little Frog Post
  • Eman Kayker
    November 1, 2019 at 8:40 am
    Hi Shane,
    Thanks for your reply.
    I am actually a sound engineer and there is no problem producing the stems but what you describe is exactly my concern.
    I want to lay down my 8 stems in a project and assign each individual tracks 1 through 8 to the corresponding xdcam output file, track 1 to file track 1, 2 to file track 2, 3 to file track 3 and so on.
    The issue I have now is that all 8 tracks in the session go to files tracks 1 and 2 as a stereo mixdown.
    Best regards
  • Eman Kayker
    November 1, 2019 at 10:44 am
    got it…
    create new seq with multichannel preset, track type ‘adaptive’
  • Shane Ross
    November 2, 2019 at 12:20 am
    Ah, sorry that I didn’t know your level of expertise. Makes what I said seem a tad condescending. Not my intention.
    I see that you figured it out though…jolly good show!
    Shane
    Little Frog Post
