Activity Forums Apple Final Cut Pro Legacy Exporting Quality Loss
  • Exporting Quality Loss
    Posted by Austin Clarence on April 28, 2009 at 9:22 pm
    Hi, any help would be appreciated.
    I’m working in a HD 960×720 – DVCPRO HD 720p60 sequence.
    Footage format is DVCPRO HD 1080p30
    Now the rendered stuff in the timeline looks great. But when I Export via Quicktime, the output is bright and horrible. What settings can I use to get the best output?
    Shane Ross replied 17 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    April 28, 2009 at 9:50 pm
    Well, your footage doesn’t match the sequence settings at all. Footage is 1080p30 running at 29.97fps and you have a 720p 59.94 sequence. DOn’t do that. Your sequence and footage setting must match exactly. Simple way is to choose the EASY SETUP that matches your footage, then make a new sequence. Or if you have FCP 6 then when you cut in the first clip to the sequence, FCP will prompt you if you want the sequence settings to match the footage…click yes.
    Shane
