Activity Forums Adobe Premiere Pro Exporting QT with 5.1 Audio Mix
  • Exporting QT with 5.1 Audio Mix
    Posted by Joshua Moise on December 1, 2016 at 10:52 pm
    I have a Prores QT with 6 tracks of 5.1 audio provided to me separately by my sound designer. I need to output a Prores file with all the 5.1 tracks baked into the file. How can I do this via Premiere? I’m seeing lots of info on how to do a 5.1 in Premiere, but not output with it already provided.
    Thanks for the help.
    Josh
    Joshua Moise replied 9 years, 9 months ago 2 Members · 3 Replies
  • Chris Borjis
    December 2, 2016 at 12:49 am
    I do this often for DCP exports.
    New custom sequence, with multichannel mono audio tracks (6 total)
    important you choose multichannel and NOT 5.1…for some reason it lowers the audio volume on export.
    Then bring in each track in order of smpte specs:
    L
    R
    C
    Lfe
    Ls
    Rs
    Then go to the mixer window and pan each track.
    L
    R
    L
    R
    L
    R
    Also make sure you check each box (in the mixer) that indicates
    L & R is mapped to1 & 2
    C & Lfe is mapped to 3 & 4
    Ls & Rs is mapped to 5 & 6
    (this keeps them all seperated without combining them all)
    Export the quicktime, in the audio options choose multichannel 24-bit.
    This is what I do and it works. Hopefully i didn’t leave out a step.
    You might search more threads in the forum going back, I know I posted
    a more detailed version of this some time ago as well as others.
  • Joshua Moise
    December 2, 2016 at 10:27 pm
    Worked beautifully. Thanks for the great intel!
  • Joshua Moise
    December 14, 2016 at 5:07 pm
    What’s good practices on including the stereo mix with the same QT? The 5.1 and all the channels output just fine, but I’m having trouble including the stereo mix.
