Activity Forums Avid Media Composer Exporting ProRes from Avid MC7 with split Audio
  • Exporting ProRes from Avid MC7 with split Audio
    Posted by Jessey Riley on August 8, 2014 at 12:39 am
    Hello,
    I’m stumped – trying to export QT ProRes file with split audio tracks.
    Here’s what I’ve done so far…
    I’ve set my audio project setting to direct out.
    I go to export and pick QT / custom, ProRes 422. For some reason “direct out” is greyed out.
    The only way I got it to work was by going export, same as source, use Avid codecs. I need the file to be ProRes not DNxHD though.
    I’m using Media Composer version 7.0.3 with Symphony option with an AJA Kona LHi card on a Mac.
    Thanks for your help!
    Jessey Riley replied 12 years, 1 month ago 2 Members · 2 Replies
  • Michael Phillips
    August 8, 2014 at 12:53 am
    Do a mixdown to ProRes, then export same as source.
    Michael
  • Jessey Riley
    August 8, 2014 at 1:06 am
    That did it!
    Thanks for the help.
