Activity › Forums › Apple Final Cut Pro Legacy › exporting ProRes 422 problems
Posted by Paul Roubicek on December 29, 2010 at 4:30 pmHello
late Merry Xmas to all
Having problems with a HDV 1080i60 project. Footage captured as ProRes 422, working time-line/Sequence ProRes 422, Render as per Sequence.
When l Export as ProRes 422 Quicktime.MOV self contained the .MOV quicktime file has problems on Movement and Cross Dissolves it’s jumping and skipping at times any advice on how to fix the problem?
the Exported project also has lost quality any advice?
I will need to make the completed project into the following files what is the best way and processes for this
the Project runs 1.45 total
1. Top Quailty DVD
2. HD Web Clip
3.HD You-tubeI understand these areas have been covered before, but l am unable to find what l am asking about
l would appreciate any advice and how to to fix my problem, l need a fix fairly Urgent
thanks in advance
regard Paul
Nolan Beguhl replied 14 years, 9 months ago 5 Members · 13 Replies -
David Roth weiss
December 29, 2010 at 4:38 pm[paul roubicek] “When l Export as ProRes 422 Quicktime.MOV self contained the .MOV quicktime file has problems on Movement and Cross Dissolves it’s jumping and skipping at times”
Sounds as if you have fields reversed. Check your sequence settings, what do they say as far as field dominance?
Also, is “Full” checked in the Render All menu? Have you rendered?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Paul Roubicek
December 29, 2010 at 5:23 pmHI David
in the squence setting l have (under general tab) Field Dominance Upper Odd
as to the other question you asked render all menu is it full sorry don’t understand where is this setting please?
l have rendered the time-line
cheers Paul
Paul Roubicek
December 29, 2010 at 5:26 pmHi David
sorry to add the render All menu have all tick but the FULL is not?
cheers Paul -
David Roth weiss
December 29, 2010 at 5:37 pm[paul roubicek] “All menu have all tick but the FULL is not?”
Check that one too and try re-rendering the timeline before exporting a Quicktime Movie at current settings. DO NOT CHECK THE RECOMPRESS ALL FRAMES BOX.
Exporting a QT Movie at current settings is a precise copy of exactly what it on the timeline. So, if yours is really different that would be quite odd. Your fields are set correctly, so if the Full render doesn’t work that will be very strange indeed.
David Roth Weiss
Los Angeles
Paul Roubicek
December 29, 2010 at 5:57 pmHi david
Same problem jumping re rendered though nothing happened as l had already rendered?
the problem is only on the moving shots not still shots (video), Do l need to deinterlace? if so How???
cheers Paul
David Roth weiss
December 29, 2010 at 6:03 pmHow are you monitoring? On just a computer monitor? If so, then you will see the interlace.
You will not see it on a real video monitor, and you won’t see it on a computer monitor if you scale the video down at least 50% from it’s native frame size.
If you are simply monitoring the canvas in FCP on a computer monitor you need to make sure to set the canvas size to exactly 100%. That will eliminate many on-screen issues, including some of the interlace you’re seeing.
David Roth Weiss
Los Angeles
Paul Roubicek
December 29, 2010 at 6:10 pmHi mate
l am using the Mac Book Pro 15inch l have (HDV Footage) though ProRes 422, the timeline looks great in FCP7 Canvas No Problems there only on Export to Quicktime
you mention the Computer will see interlace? the project is for a DVD to play on a display TV at an airport though a Quicktime file they may also need and also the Web as a HD clip and also for Youtube will l see the same problems when play and converted to the above mentioned formats l need???
appreciate your help
paul
Paul Roubicek
December 29, 2010 at 6:11 pmsorry to add
the footage is 1440×1080 and time line the same
paul
Tony Brittan
December 29, 2010 at 7:39 pmWhat type of drive is the playback from? Is it USB? Or worse, the system drive? If it’s on a separate drive that’s fast enough, I don’t know what to tell ya. If it’s USB or your system drive that may be the problem. Is it smooth playback from the timeline?
Tony Brittan
Owner – Island Shore Productions -
Tony Brittan
December 29, 2010 at 7:44 pmBTW…that was for the non-smooth playback after export. The other, encoding, questions are lengthy discussions for each. If you search here, you’ll find a ton of info! Compressor is your friend. Learn it and life will have joy!
Tony Brittan
