Activity Forums Apple Final Cut Pro Exporting Project- but dreaded Missing or Offline Files
  • Exporting Project- but dreaded Missing or Offline Files
    Posted by Suree Cruz on October 12, 2016 at 7:49 pm
    I’ve read the boards on this topic, but can’t find an answer to my frustrating problem. I’m working in 10.2.3, my project is finished and there are no red clips or with “missing/offline” files, but the actual project file (“sequence”) has the little triangle with exclamation point. Is there a way to figure out which clip(s) are the problematic ones? The message comes up “The item cannot be shared while it’s still referencing media on the camera”. I’m not sure which clips are referencing media. Assuming it’s some of my AVCHD clips.
    I’ve been using X for a year, but only recently had to manage my media without an assistant and needless to say, I’m learning the hard way about reference files and not moving things around outside the program.
    Hoping someone can help, so I can relink the clips and export this project. I have done a “select all” and relinked the clips in the project timeline. It says that none are “missing”, but I do it anyway. Problem not fixed. Also, the clip window has no offline clips, titles, graphics.
    Jeff Kirkland replied 9 years, 11 months ago 5 Members · 12 Replies
  • 12 Replies
  • Noah Kadner
    October 12, 2016 at 8:54 pm
    You need to reimport clips from the camera as this warning is thrown when you have clips that weren’t imported. Or were later lost/moved in the Finder. Easiest way to do is remove suspect clips one at a time. Hopefully you saved the originals…
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Suree Cruz
    October 12, 2016 at 9:00 pm
    Thanks, Noah.
    So you don’t know a way to determine which are the troublesome clips? Like I mentioned, they are all showing up in the project timeline and playback fine, it’s only on export (share) that I receive the message.
  • Jeff Kirkland
    October 12, 2016 at 9:17 pm
    Are your clips internally or externally managed? I’m wondering if you are referencing clips that are still in copies of their original camera card directories so final cut thinks they are still on the camera.
    You might try consolidating the media.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Suree Cruz
    October 12, 2016 at 9:24 pm
    Thanks, Jeff.
    I tried consolidating my media and the same problem occurs. I don’t see how the clips could be referencing files on the card because I store my SD card files on a separate hard drive that’s not connected when I edit. I’m guessing I moved around a clip on the hard drive to sort it. Most likely I’ll have to do a clip by clip reimport, but I was hoping someone could direct me to a place where you can see which clip(s) is the one that’s unlinked? Is that feature possible in FCPX?
  • Noah Kadner
    October 12, 2016 at 11:20 pm
    What happens if you try to export with that external drive reconnected?
    Noah
  • Jeremy Garchow
    October 13, 2016 at 2:41 pm
    I find this happens when a clip hasn’t finished importing all the way.
    FCPX will leave an improper symbolic link (alias file) linking to the original media. If you can find the errant file, you can delete the alias, and reimport.
    Are your transcoded (imported) files inside the library, or external to the library?
  • Brian Thomas
    October 13, 2016 at 3:04 pm
    To find a problematic clip I’d ‘Duplicate the Project’ and in the duplicate delete all clips to (say) the right of the centre point and see if the problem goes away. If not then it is somewhere on the left of that point. Duplicate again (if necessary) and keep halving and halving until you’ve zoomed in on it.
    FCPX and PPro 6. iMac 24 + MBP 15″. Near Geneva, Switzerland
  • Suree Cruz
    October 13, 2016 at 4:02 pm
    I tried that last night to see if it could read the card files that were on the backup drive, but no luck. I think at this point, I’ll just have to do the one clip at a time thing. It’s frustrating that there is no “clip info” or anything to see which clip is the unlinked/reference clip.
  • Suree Cruz
    October 13, 2016 at 4:04 pm
    Thanks, I was trying to avoid this process, but it seems that’s where I’m at. Wish there was a way in X to have the clip info tell you. Most likely they didn’t import correctly.
  • Suree Cruz
    October 13, 2016 at 4:25 pm
    Probably. My clips are in the library. But from now on, I’m going to import all footage into a central ‘footage’ drive. So I can avoid these issues working with multiple libraries, events and project. I have to say, this media management for me is a major hurdle and probably will result in shifting to premiere. I’m not a metadata person, so not being able to sort clips and see which clips have issues, is a big problem- especially working on a long format documentary.
