Activity › Forums › Apple Final Cut Pro Legacy › Exporting Photos in correct Aspect ratios
  • Exporting Photos in correct Aspect ratios
    Posted by Brian Findlay on May 24, 2007 at 9:25 pm
    I’ve been trying to figure this one out off and on for several months. My problem is not how to export it, because I want 16:9 frames but have 1440×1080 (HDV), they do not export to 1920×1080 as they are seen on the screen..everything is squished. What I have tried is Export->Quicktime Pulldown[Still] (?) and select a variety of formats.. I would hope for JPEG..something I could use as a still when making a DVD Menu.
    If anyone knows a simple way I would appreciate an explanation.
    Andreas Karoliussen replied 19 years, 4 months ago 4 Members · 5 Replies
  • Russell Lasson
    May 24, 2007 at 9:30 pm
    HDV is 1440×1080, not 1920×1080. FCP knows that and stretches the image. But QuickTime Conversion doesn’t recognize that it needs to be stretched, so you end up with a 1440×1080 image.
    The same thing happens with anamorphic SD or even normal SD for that matter (720×480 should be 640×480 to look right).
    I use a Photoshop action to open all the images in a folder and resize them (in your case, from 1440×1080 to 1920×1080).
    I’m sure there are other ways of doing it too.
    -Russ
  • Jeremy Garchow
    May 24, 2007 at 9:37 pm
    [Russell Lasson] “I’m sure there are other ways of doing it too.”
    I have found that Photoshop is the best and most automated way to do it as well.
    Jeremy
  • Andreas Karoliussen
    May 25, 2007 at 8:21 am
    Hi, Ive been trying to figure out a way to export stills with proper aspect ratios, however I rejected that It wasn’t possible in FC. but haven’t gotten around to figure it out. But If its impossible, why not use iResize?
    simple and can batch export.
    https://mac.softpedia.com/get/Graphics/iResize.shtml
    Andreas
  • Brian Findlay
    May 25, 2007 at 11:03 am
    I tried it, a nice idea, but the program only goes up to 1680, not full resolution of 16:9. If you know anything free or near free that does this easily, please let me know.
    Brian
    May 26, 2007 at 7:57 pm
    Hi, Ben
    Sorry I led you in the wrong direction, did not now the limitation, I only work SD.
    However you can try Picture Resize Genius if you have a windows based box:
    https://www.freedownloadscenter.com/Multimedia_and_Graphics/Graphics_Editors/Picture_Resize_Genius_Download.html
    It can export full HD 16:9
    If you prefer mac; google “image resize free mac” and you will find a few free and a some free to try.
    Good Luck!
    Nice if you posts back if you find a good one;-)
    Andreas
