Activity Forums Media 100 exporting out of 8.1 Please help!
  • exporting out of 8.1 Please help!
    Posted by Viktor David on January 13, 2009 at 5:29 pm
    Hello M1oo gurus!
    We have a project, created in 8.1 xs back in 03. What’s the best way to export it, so it can be brought up in modern world environment and eventually output to digibeta in a post house? We tried export as QT movie with best settings. However, it opens on G5 and macpro seriously distorted – black level was way up, banding, etc. We also tried to export it as a self-contained movie, it only took 11GB for a 48′ program, and also looked way worse than when opened in native M100 8.1 .
    Vic
    Studio 7NY
    G5 Dual 2 Ghz, Leopard, FCP Studio 2, Blackmagic HD, ATTO UL4D, MOTU V3HD
    Viktor David replied 17 years, 8 months ago 3 Members · 5 Replies
  • Jim Brodie
    January 15, 2009 at 10:13 pm
    You might try exporting in another codec where you can alter more settings
    Media100 Export
    range or program
    Other
    Field dominance: progressive
    Colour Range – 0-255
    Options
    Settings
    Compression type: none, motion jpeg A or Media100HD (animation sometimes introduces jitter)
    Motion
    Frame rate: 29.97
    Key frame: 300 frames (or blank – when compression is set for
    Compressor :
    Millions of colours plus
    Quality – best
    Size:
    Compressor native
    check Deinterlace Source Video
    Prepare for internet streaming
    uncheck fast start for
    This is how I prepare segments for web streaming. Hopefully it might give you an idea on how to proceed. Often the Motion jpeg-a or animation codec work best.
    Cheers,
    Jim
  • Viktor David
    January 21, 2009 at 12:54 am
    Thank you. We’ve downloaded trial producer 13.0 to be able to export it out of later version of M100, with more options to export. So, you suggest to export interlaced Betacam SP video with lower field dominating as progressive and then deinterlace it? Our final destination will be Digital Betacam.
    Studio 7NY
  • Floh Peters
    January 21, 2009 at 7:34 am
    [Vic David] “So, you suggest to export interlaced Betacam SP video with lower field dominating as progressive and then deinterlace it? Our final destination will be Digital Betacam. “
    The question is how you are going to DigiBeta. From FCP? Avid? A new Media 100 system? Deinterlacing does not make sense if you are going back to tape, but you need to keep the field order correctly. If you are going to a Apple codec you definitely should use the Computer (0-255) export option.
  • Viktor David
    January 21, 2009 at 7:52 am
    Hello Floh,
    Since we don’t own a digibeta deck, the most economical way to output it is to export a QT movie and drop it off at the dub house. So what would be the best way to export it? We got producer 13 trial version for several more days. The dubhouse suggested uncompressed at least 10 bit 48k.
    Thanks a lot,
    V.
    Studio 7NY
  • Viktor David
    January 21, 2009 at 7:55 am
    We just exported and it gave weird green line at the very top of the screen for every single title card… is that 720×486 issue?
    Many thanks,
    V.
    Studio 7NY
