Activity Forums Apple Final Cut Pro Legacy exporting NTSC
  • Posted by Ian Haig on May 18, 2010 at 5:37 am
    I have a question I was hoping you may be able to help me with.
    1. I have a DV PAL movie made from Final Cut Pro, I needed to send this on DVD to the US, so I actually used TOAST and re encoded the DVD as NTSC which was probably a dumb thing to do, it made an NTSC dvd, most of it is OK, however on certain bits of movement I get a sawtooth look, which i assume is a interlace or field issue. I see this when I play it back on a PAL TV, MY DV PAL movie plays fine.
    As I have sent a number of these DVD’s off to the States, will this interlace/sawtooth problem appear on TV’s in the US ?
    2. When making another NTSC movie from my PAL DV, I put a shift field filter on my PAL DV movie and put it to LOWER and when I exported this new NTSC movie it played fine..is this what I should do ? what is the best way to export a NTSC movie from FCP should I be using compressor ?
    thanks
    ian
    Sascha Engel replied 16 years, 4 months ago 3 Members · 2 Replies
  • John Fishback
    May 18, 2010 at 10:56 pm
    I’m not expert in standards conversions. The couple times I’ve done it with software I used Graeme Nattress’ Standards Converter. I’ve seen people discuss successful conversions with Compressor, but I have never used it for that. If you search, it’s possible you’ll find a Cow tutorial about this. I seem to recall one.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Sascha Engel
    May 19, 2010 at 9:19 pm
    There is several ways to convert from and to NTSC:
    1.) The most simple one, which I used a couple of times and the result is pretty good: I imported the footage onto a Timeline with the settings of the original footage and exported it into the settings I wanted.
    2.) The Nattress one mentioned by Johne works very well.
    3.) Friends of mine did it with Compressor and it was doing a good job as well.
    4.)Download the App “MPEG Streamclip” – it’s for free – also working very nicely on NTSC Conversation (A great App panyway, if you want to convert DVD Footage back to Quicktime!!!!)
    Sascha
