Activity › Forums › Adobe Premiere Pro › Exporting My video to .mov – really bad quality
  • Exporting My video to .mov – really bad quality
    Posted by Nicotone.com on July 4, 2006 at 11:54 pm
    Hi, I am trying to export my video created in Prem Pro 2 to a .mov file.
    The only codecs that seem to give any kind of good quality in the QuickTime option is ‘Apple DV’, but even that is pretty bad. I can only just read the text.
    The movie I am trying to convert contains the usual content like, short snippets of video, images, titles, all with animations.
    You can see it at: https://www.knowledge-partners.com/tech-showcase/nemo.htm
    It has exported ok to MPEG and WMV. The link above contains a FLV movie which was created by converting an avi file exported from Prem Pro 2.
    Any hints for this one? I need a .mov file for a friend who is on an AppleMac.
    Anyone else have this problem of bad .mov quality, but everything else out of the Prem Pro Media Encoding Manager (or what ever it’s called?) is ok? What codecs are the best? Are there better downloadable ones?
    Any suggestions are always welcome,
    Thanks for reading,
    Cheers,
    Nico
    If life serves you lemons, make lemonade!
    Nicotone.com replied 20 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • Vince Becquiot
    July 5, 2006 at 1:55 am
    For the best Quicktime quality (Quite a large size).
    Choose export> Movie
    In settings > General (left tab) Choose file type: Quicktime
    Under Video (Left tab), choose compressor: animation. Quality 100%
    Cheers,
    Vince
  • Dave Friend
    July 5, 2006 at 4:39 pm
    Nico,
    When viewing a mov file using the QuickTime player be sure to set the movie’s properties to use “High Quality Enabled”. Often the file will look horrible but it is only due to this setting of the player.
    Hope this helps.
    Dave
  • Nicotone.com
    July 5, 2006 at 9:25 pm
    Hi Guys,
    Thanks for the help. I have managed to create a .mov file from the File>Export>Movie menu.
    Although it is a really … really … really large file that is created. Unfortunately if I export the whole sequence, which is about 6 minutes long the export completes but with no file. I can’t find it. So I tried just 1 minute and it created a .mov file (great quality but 1.6gb in size).
    Is this right? I’ve tried the quality at 75% and 50% set on Animation, but the export of the whole sequence still has the end exported .mov file missing. Are there any other settings you would reccommend?
    Thanks again,
    Cheers,
    Nick
  • Dave Friend
    July 6, 2006 at 3:36 am
    [nicotone.com] “Is this right?”
    Yup, sounds about right. The Animation codec is pretty close to uncompressed and carries an alpha channel to boot. An hour long segment would probably run well over 72GB.
    What format is the project set for? Is this a DV project? You should be able to get a good quality DV format quicktime from a PPro project that is set for DV format.
    Dave
  • Nicotone.com
    July 6, 2006 at 11:07 pm
    Thanks for the suggestion.
    If I’ve read your reply correctly – I’ll try exporting it to .mov using the ‘DV Pal’ setting.
    Just to confirm, I’ll do this by going File>Export>Movie >> Quciktime>> DVPal Format. The project was set up as a DV Pal (I’m based in the UK)
    I’ll have to leave it over time exporting as it takes a little while. I’ll let you know how it goes.
    Thanks again,
    Nick
  • Nicotone.com
    July 6, 2006 at 11:18 pm
    In the above thread – “over time” should have read “over night”
    Cheers
  • Mbelli
    July 6, 2006 at 11:33 pm
    I haven’t been very impressed with Adobe Media Encoder’s output to Quicktime. In addition to taking a long time to encode I find it buggy and of inferior quality. Luckily I have Canopus Procoder which does a much better job with Quicktime.
    In regards to PP2 and WMV or FLASH, I’ve found both to be of really good quality and encoding time is pretty close to what I get with Procoder. MPEG-1 is also very good but MPEG-2 is average, especially with material which has a lot of subject or camera movement. Procoder MPEG-2 is clearly superior especially at very low bitrates.
    Anyhow, those are my personal observations, others here might have had different results. Maybe Adobe will clean up it’s act in regards to Quicktime next PP update, I wouldn’t t put much faith on it at the moment.
    **** ALSO, don’t forget to enable the deinterlacing checkbox on the top right befofe encoding, it yields better quality and far sharper encodes.
  • Nicotone.com
    July 7, 2006 at 6:35 pm
    Hi Guys,
    Thanks mbelli for the Procoder recommendation, I’ve downloaded the demo and will give it a go.
    However I think I found a solution – Hoorraaaa!
    I did the following:
    File > Export > Adobe Media Encoder >> QuickTime >> Apple DV – PAL (codec)
    This created 7 quicktime files all set for different modem speeds.
    The files ranged from ‘1 Mbps Cable.mov’ (34mb in size) to ’56 Kbps Modem ISDN.mov'(1.1 mb in size).
    The quality was the bet I’ve seen so far and didn’t explode in size e.g. 1.5gb, which I was getting before.
    The only thing I couldn’t figure out, was that the files were saved in my top level :C drive, and not in the folder I thought I saved it in. Oh well!?!
    Hope that helps anyone doing the same stuff.
    I’ll give Procoder a demo as it talked about being able to act as a plug-in in PremPro and may give even better results?
    Cheers everyone,
    Nick
