Activity › Forums › Adobe Premiere Pro › Exporting multichannel audio quick times for qc
  • Exporting multichannel audio quick times for qc
    Posted by Sean Davison on November 17, 2019 at 9:39 pm
    I’ve just failed a qc because my audio tracks were not named/tagged correctly
    I can’t work out for the life of me how to do that in premiere
    I’m exporting a pro res uhd qtm.
    All the tracks are named correctly in the sequence set up and I’m exporting 10 streams of discreet audio but the track names aren’t getting into the metadata tags
    Any ideas?
    Life on the Bleedin\’ Cutting Edge….
    http://www.1handclapping.co.uk
    John Pale replied 6 years, 10 months ago 2 Members · 1 Reply
  • John Pale
    November 19, 2019 at 1:36 pm
    Don’t click the Discrete button when you encode. That makes all the audio tracks have no track name metadata. That’s basically the only difference from leaving it at the default setting. This is buried in the manual someplace as if it were not important.
    You can’t fix the metadata in on an already encoded file in Premiere. You can do that in QuickTime 7 Pro Player if you still have it.
