Activity › Forums › Adobe After Effects › Exporting .mpeg
  • Exporting .mpeg
    Posted by Christofer Wetterholm on October 14, 2009 at 3:10 pm
    Hello there!!
    I have a big question,
    i´ m trying to output a mpeg2 programstream with the fileextension.mpeg or .mpg but i only get a file with the file extension.m2v
    Is there anyway to do this in aftereffects or do i have to do it in another aplication?
    The file is pal 720 576 anamorphic and i need to upload it to finish tv chanels and they request a mpeg2 file.
    /Christofer
    Kevin Camp replied 16 years, 11 months ago 2 Members · 2 Replies
  • Christofer Wetterholm
    October 15, 2009 at 7:59 am
    Thanks!! I have tryed with compressor and cleaner but with no luck at all.
    But yesterday i tried a demo of episode telestream and it seems like it will do the job.
    Anyway i hope so
  • Kevin Camp
    October 15, 2009 at 2:23 pm
    if you have cs4, you should have adobe media encoder. it will create a .mpg mpeg2….
    ame can also render a comp from a ae project file, select the ae project when importing, then select the comp… although i still render from ae and import that into the utility… maybe i’m too old — or i just need time to do some test comparisons. i have noticed that ae rendering is usually faster (w/ mp enabled) than ame, for whatever that’s worth.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
